I am comparatively new to the world of "Prestressed Concrete", though a bit experienced in Steel Design.I have been reading the "ADAPT" software manuals and have the following clearifications:
After structural modeling and data entry in ADAPT we run the program and then the "Recycle Window" appears wherein we can adjust the post- tension forces and the tendon drapes. I have read the ADAPT manual but have the following clearifications:
In the "Recycle Window" we have the following tabs:
a)Tendon Forces and Heights
b)PT Forces
c)Required Forces
d)Stresses Tension and Compression
Now, I have the following clearifications:
1) In the "Required Forces Tab" we have a section of , "Governing Forces","Based on Tensile stresses", "Other Considerations"
The manual says that under the "Governing Forces", the force selected is th e largest based on tensile stresses, minimum P/A, minimum percentage of dead load to balance.When we say based on tensile stresses does it mean the force selected is one such that the value of tensile stesses due to Dead Load +Live Load+Post Tensioned Force is not more than the permissable tensile stress value?When we say, based on minimum P/A does it signify the value of post-tensioning force is such that it should create minimum precompression in concrete specified by the user?The other consideration, is the percentage of dead load to balance, does this mean the force selected is one that
the percentage of dead load specified by the user should be balanced?
Am I right here?
Next question,
2) What is the basis/logic of specifying the minimum precompression?
What should be the value of the minimum precompression?
3)Considering, the "Tendon Forces and Heights" tab, here the user can vary the forces in any of the spans and the software checks for the adequacy of stresses,etc.
Now, if we have a different PT force in each span (mode selection is "Force Selection" , would this indicate that we have a different tendon of different strength in each span?
If the PT force in each span is different, then we cannot have the same tendon running through all the spans, right??
b)PT Forces
c)Required Forces
Am I right here?
Next question,
