post processing
chourouk
41
Hello
How I can automate this part for a vector that contains n node?
xy0 = XYDataFromHistory(odb=odb,
outputVariableName='Reaction force: RF3 at Node 1 in NSET NODE_BOUNDARY',
steps=('Static_definition', ), suppressQuery=True) # read results from nodes Forces
xy1 = XYDataFromHistory(odb=odb,
outputVariableName='Reaction force: RF3 at Node 2 in NSET NODE_BOUNDARY',
xy2 = XYDataFromHistory(odb=odb,
outputVariableName='Reaction force: RF3 at Node 3 in NSET NODE_BOUNDARY',
xy3 = XYDataFromHistory(odb=odb,
outputVariableName='Reaction force: RF3 at Node 7 in NSET NODE_BOUNDARY',
xy4 = sum((xy0, xy1, xy2, xy3, ), )
xy_result = session.XYData(name='SUM_FORCES', objectToCopy=xy4,
sourceDescription='sum((Reaction force: RF3 at Node 1 in NSET NODE_BOUNDARY, Reaction force: RF3 at Node 2 in NSET NODE_BOUNDARY, Reaction force: RF3 at Node 3 in NSET NODE_BOUNDARY, Reaction force: RF3 at Node 7 in NSET NODE_BOUNDARY, ),)')
thanks
a) Cycle for you node number and replace that string in the name. Save each curve with a specific string and add that string into a list. Convert the list into a tuple and use it in the sum command.
or
b) Access the history data directly and do the operation with them. Add the result back into the viewer session if needed.
I wrote like that but it shows me an error
"list=[]
for i in NodelabelList :
outputVariableName='Reaction force: RF3 at Node'+str(i)+' in NSET Forces',
steps=('Step-1', ), suppressQuery=True) # read results from nodes Forces
list=list+str(xy0)
tuplelist=tuple(list)
xy=sum(tuplelist)
xy_result = session.XYData(name='SUM_FORCES', objectToCopy=xy,
sourceDescription='sum(tuplelist)')"
"history output cannot be located for the variable: Reaction force: RF3 at Node 75 in NSET Forces in the step specified'
