I have a one-way slab (non-PT) spanning over PT beams. The concrete strength was either poured wrong or is coming in way low (4,000psi vs 6,000psi spec'd). When I go back to look at the design with the lower concrete strength, I get 18.3.3 failures (i.e. tensile stress at service load failures) f.t is greater than 12*sqrt(f'c). If I change the class, from class T to Class C, then I get a design that "passes". I think ultimately beam deflection will be an issue since we will need to use cracked section instead of gross section properties. However, if deflection checks out is there anything else that you see being an issue here? It just feels wrong that I can simply change the class and everything is "OK".
If deflection is an issue, I'm thinking we may need to come up with some sort of external post-tensioned repair. Any other ideas or direction/examples on external PT repairs?
