Potential Transformer Primary Fuse Basis for Sizing 2
brainsalad
33
Greetings:
Would be grateful for your thoughts regarding the origin of any bases used for the inrush capability of primary fuses for potential transformers.
I have a GE JVM-3 PT (2400-kV, 750-VA) with an EJ-1 fuse. Also an ancient ITE PT-6 PT (600-VA, 480-V) with Gould A6Y7E-96 fuses......
Can anyone recall the origin or basis of the requirement to have primary fuses tolerate at least 12x (or 25x) rated primary current?
Thanks for your help.
Guys-
The HV fuses for PT's aren't there to protect the PT. they're in the circuit to prevent a PT fault from affecting the source switchgear/buswork.
old field guy
All:
Thank you for your contributions.
I first set out to answer my original question, "[What is] the origin or basis of the requirement to have primary fuses tolerate at least 12x (or 25x) rated primary current?", but have been delighted in learning more than I have wondered.
After searching, one answer to my original question is found in IEEE-242 (Buff Book), which describes the basis for that requirement as derived from the "hot-load pickup" phenomenon, which requires magnetizing inrush points at 14x FLA at T=1s and 28x FLA at T=0.01s.
A nice article on the subject (but not necessarily for PTs):
Now wondering "why not" the same criteria for 480-V PTs (above is all medium voltage).....
