Since it is Fiber Optic, there is no risk of electromagnetic interference. Also, please note that in a 220 kV Over Head Line (OHL), it is common to take the fibers through the OPGW (Optic Fiber + Ground Wire) conductor. These fibers are along with the phase conductors for many miles.
Please don't forget that these fibers are used for critical applications such as substation to substation communication, SCADA, Feeder Differential protection etc. This is a common practice, even in KSA (Kingdom of Saudi Arabia??). By the same token, I do not see any reason, why the same conduit cannot be used, unless there is some abnormal temperature rise issues are the limitation.
