mpparent
- Sep 26, 2001
- 399
All,
I have a PDU(600V-208/120V, 3PH), that has recently been showing signs of a strange problem. The unit has been tested and gone over in prior years, THD measurements, voltage/current measurements, etc., with everything in tolerance. Last year for instance, the voltage at the output of the xfmr was about 209V phase to phase. The input voltage was 600V. This year, w/ the same input voltage, the secondary measured at 214V phase to phase between all phases. Any ideas as to what's going on?? There's only about a 3% THD on voltage, and all of the neutral to ground voltages measure 0.
