zoo123
- Aug 29, 2004
- 21
power factor issue at my shed , seek advice?
dear friends, i have a commercial power line taken from Govt owned lines, as is usual.
with my new start up, i registered for a min. use of 4kw and connections provided in 2021. I changed the same to permanent conneciton in end of 2023.
Since, then i have been using one welding machine mobile carry type and one hand grinder for weld work related fabrications. The wattage of weld machines never exceeds 2 KW,
and the hand grinding machine 0.5KW.
RECENTLY I WAS levied a heavy penalty for a very low power factor of 0.2. But, when i see the digital meter it shows 0.07 or around that.
I also, use a Capacitor bank unknowing on the conneciton method. but they keep charging me once again.
Now, upon, raising the query, the capacitor bank trader says for 4 to 6kw , this is an issue for low power and it can never be solved.
The govt department adviced me not to keep the capacitor nearr the mains, but shift it to my welding machine and switch it off and swith on during the usage only.
i am perplexed and unhappy that my start up is being robbed for no reason of mine. can i know what i must do to increas the pf and avoid the fines. please advice me.
thank you all.
thank you all.
