insinyur02
good morning,
i am a new graduate working in cogen power plant.
- i want to know, can i increase power factor to 1.0 from the steam turbine generator by increasing voltage from voltage regulator.
- in our plant, power factor is 0.82 from generator.... if i increase voltage from voltage regulator to have power factor to 0.95 , is it possible?, what will happen to the generator and the system?
- why my bos never increase power factor to 0.95, as i know higher PF means reactive power lower and it is good.
please explain.... thank you
