bigheadted
- Jul 22, 2005
- 53
Is there a problem with setting the targer power factor of a capacitor bank to unity? bearing in mind it is one of three independently acting capacitor banks the other two are set for 0.98.
What is the minimum switching time i should be using to switch in and out capacitors? and what are the limiting factors?
i understand that changing these settings is not ideal but the transformer supplying our site is at its maximum, after contracted maintenance to our pfc i have seen the pf drop very low causing higher than usual currents on ramp up of the machine. i would like to set the pf to unity and increase the sitching time in attempt to improve the situation untill we are in a position to get a larger transformer
thanks
thanks
