What are some of the causes of a low power factor. Usually the power factor at most of our traction substations is .96 lagging however one particular substation is 0.5.
Substation layout:
Primary of transformer : 88 kV 3340kVA
Secondary : 2x2364 V note there two secondary windings 2x2362 kVA
Load : 6 pulse diode rectifier : Output voltage 3kV dc
3kV feeds onto overhead power lines where trains acquire their power via pantographs.
Substation layout:
