fuseshut
- Oct 16, 2005
- 76
I got a basic question regarding power resistors. I know when specifying a power resistor, the power rating shall be twice the expected dissipated power. For example, I am using 3000 ohm, 10W resistor in a circuit application in which 120VAC will be across it. It is a nice power resistor from ohmite, 20 series. If you do the simple calcs I am only drawing 40mA, which gives me 4.8Watts. now it is a 10W part and it is still getting hot to the touch. I even lowered the AC voltage down to 100VAC , which gives me 3.68W and is still getting hot to the touch. It is not a heatshinkable resistor, it's one of the tubular, ceramic axial leaded resistors. I ran it for 10minutes across 120VAC, then 30minutes just to make sure the resistor wouldn't burn up. And it did not. Measured it and still read 3000 ohms on the meter. Current was steady also! In the end application the power resistor will be sitting inside a enclosure full of oil. So the oil will keep it cool. I'm just curious on why they get so hot, even at 3.65W (10W rated part), and there is no heatsink required (so the datasheet states).
