Could someone give an opinion on this power supply,
It's a Tenma 72-7700, If it says 24VDC and 15 amps on the spec sheet, will it provide 15 amps, or does the word "limited" hint it might make 15 amps at some lower voltage than 24VDC. I'm so confused. I bought thru Newark In One.
A coworker has done a short test and thinks it's not a 24VDC x 15 amp unit.
Thanks,
kch
Thanks,
kch
