rory pringle
Agricultural
- Nov 28, 2024
- 2
Trying to work out geared electric motor required for turning a rotary drier:
18 m 1.1m diameter pipe weighing 4 tons lying horizontally on frictionless bearings.
Weight of material being turned is 500kg wood shavings.
Pipe has a chain driven ring gear outside diameter 1.2 and 83 tooth chain drive.
Rotational speed variable 2 cycles per minute to 6 cycles per minute
Drive sprocket 30 tooth.
Can someone help?
Can someone help?
