Emadshaaban1987
Dear Folks,
Power transformer 20kv/6.6kv 5MVA ,transformer outgoing tripped by (27),l1=6.2 l2=5.5kv l3=4.3kv ,it seems that the voltage dipping is in one phase only L3
the transformer is protected with many protection units (87T,50,51,64) but non has popped up except 27
-no new load was engaged
-transform tests including IR ohmic and ratio tests was done successfully
-its a real under voltage because downstream feeder has detected this voltage dipping .
the transformer loads are 2MW loading pump, street lighting (feed through 6.6/0.4kv transformer )
any tips
any tips
