Powercopy of elements inside a sketch
do you really need a sketch?
regards,
LWolf
Actually yes, all the lines (piping routes) need to be in a sketch.
I needed to rapidly instantiate some 14mm lines (spacers) and some arcs with different radii (30,45, 90deg elbows). I got it done manually in 30min but i would have loves to have some predefined stuff.
Best regards,
Costin Ruja
vba could do, but not super easy... but again I am asking : do you REALLY need it in a sketch?
if your route is planar, you can do GSD geometry / powercopies then when done, make a join of it then project the join in sketch
Eric N.
I really like the flexibility of a sketch, you can pretty much know how will the routes look and modify them in one step, also you can have a visual confirmation when you f* up a route (collisions, bend radii..).
Working with GSD elements I have to constantly add some here, substract some there, constantly double clicking.
I am still trying to maybe have some hybrid approach. The job gets done anyway, but I would like at least to halve the time it takes.
Best regards,
Costin Ruja
I can see the video, it seems this is one way to go.
Best regards,
Costin Ruja
yeah, its not that much difficult to make it [pc3]
If you are interested i can make it for you.
