onload
- Dec 2, 2006
- 9
Dear Engineers,
I am working with LED light displays. There is a series chain of 5 LEDs whose brightness must be controllable. This series chain is across a 24V DC supply. There is a series NPN transistor in series with the LEDs which "burns off" excess volts if the LEDs need to be dimmed. This series NPN has its base fed by an op-amp which has a 0-10V input supply. -The brightness of the LEDs is thus controlled by adjusting the 0-10V supply. -However, the series transistor is "burning off" excess volts inefficiently. -Does anyone know if it is feasible to apply volts to the LEDs using a switch mode convertor?
Their are hundreds of these series LED chains and i think it would be saving electricity to use a controllable switch mode convertor to apply volts to the series bank of LEDs.
Any thoughts greatly sppreciated.
