Pickaspot
- Jan 31, 2015
- 5
The application this will be used for in the field is a steam line with a design temp of 869F and design pressure of 769 psig. The weld's are open butt on 1/2" diameter SA-335 P-11 to SA-312(316)both having a wall thickness of 0.147" The engineering spec requires that max hardness not exceed 225HBW they do not require PWHT per the t.
My planned PQR variables:
Pre heat of 300F
Process- GTAW (manual)
Base metals-
Pipe/tube specification SA-335 (P-11), nominal composition 1.25Cr-0.5Mo-Si, P-4 Group 1, Nominal pipe/tube size 4” Schedule 80s, 0.337”t
Pipe/tube specification SA-312 (TP304L) nominal composition 16Cr-12Ni-Mo, P-8 Group 1, Nominal pipe/tube size 4” schedule 80s, 0.337”t
Filler material-
ERNiCr-3, F-43, SFA 5.14, UNS# N06082
Single bevel groove w/o backing
Shielding gas (A5.32 SG-A)
Backing gas (A5.32 SG-A)
Typically 309 would be used for joining these two base metals? I concluded with consideration of the design temperature that the Inconel filler would be best utilized for this procedure.
I have a couple of questions.
1. Does this look like I am on the right track?
2. Should I go ahead and have impact's done on this PQR, I can't find any data for minimum design temp!
Thank you for your consideration and input of my first dissimilar PQR plan.....!
Pre heat of 300F
Base metals-
Filler material-
