JeanMicheling
Hello everyone,
I have a special application with a spindle that is planing wood. I'm looking for a way to calculate the load on bearings in operation. Since there are too many variables, it's almost impossible to have a good approximation by theorical calculation. Thus, I'm looking for a practical way to measure the load. I thought I could have a good value by measuring the deflection of the shaft in operation and then, evaluate the bearing load. My concern is about the way to calculate that value. Should I only compute the bearing deflection or the shaft deflection or both. The spindle has a pair of angular contact bearing 15 deg 100mm-150mm ligh preload at each end. Is there a general thumb rule for that? Will it be a good approximation to only calculate the bearing radial deflection?
Thanks,
Thanks,
