abaqus1234
Bioengineer
I'm running an explicit analysis where I am importing a pre-defined field (initial state) from another Abaqus model that I ran earlier. I keep getting an error in Abaqus packaging. However, I tried to map the initial field from another file and it seemed to run successfully, so I think there's something wrong with the results file of the model that I am trying to import from rather than the second simulation that I am running.
This is the only error that I am getting:
***ERROR: Abaqus/Explicit has encountered an internal error during the
***ERROR: analysis. Please report the issue to local office.
I have already searched the error and tried the 1 proposed solution that I found online ( and this did not resolve my issue.
Is there a way for me to check my RES file to see if there's something specifically wrong with that file?
The only thing that I can see is that the files that I am successfully able to import pre-defined fields from were run on my local computer vs the files that I can't seem to import from were run on an external server called Compute Canada.
Any insights would be helpful!
