PSUengineer1:
That is some sort of a crimped, semi-pinned (low fixity or moment cap’y.) joiner connection. Boy is that a mouthful. There is most likely a pre- bent connecter bar or tube inside, maybe slightly press fit into the two outer crimped tubes, to keep them aligned and generally in contact with each other. Maybe some final crimping in place, maybe a couple screws or through bolts? The two part (left half and right half frames) are kinda like a gable frame, but pinned at the ridge. They act kinda like a three hinged arch, in gable frame form/shape. We know nothing about the knee details of those frames, those will be the highest stressed regions on the frames, or any bracing systems, you haven’t shown us that. I’ve not seen that exact detail before, but I’ve seen those light cover structures before, to cover boats, farm machinery, cars, etc. They keep most of the rain off, they slough some snow sometimes, given their shape, and they blow over or lift-off fairly easily.
Pre-engineered may be a bit of a misnomer, and suggest that there may be some real engineering calcs. and package behind them somewhere. Pre-manufactured, kit built, framing system or framing package may be more applicable. Ask them for a set of P.E. stamped engineering drawings and see what you get. Ask them for a stamped letter/report, stamped by a P.E., certifying that those structures meet the local building code and see what you get. I’ll bet you won’t get them to call that a code compliant building system. It’s a cheap storage shed, but they don’t like calling it that.
