pre memory 1
navigator30
24
I get the following error message:
IT IS NOT POSSIBLE TO ESTIMATE THE TOTAL AMOUNT OF MEMORY THAT WILL BE REQUIRED. PLEASE INCREASE THE VALUE OF PRE_MEMORY
CAn anybode tellme what to do???
thanx a lot!!
How much memory have you allocated to pre so far? That is, have you put a line like this in your abaqus_v6.env file?
pre_memory = "1000Mb"
If you are using ABAQUS/CAE to craete/submit the job, what memory did you allocate in the jo dialog (look at the third tab along)...
Sounds like you need to allocate more, as per the message ;)
