Pre-stressing of strands in concrete beam
Zain_117
22
I am trying to model prestressing in strands in a beam. I got this error as below.
"Surface-based COHESIVE BEHAVIOR cannot be used for contact pair interactions. See the surface interaction named INTPROP-1"
My purpose is to apply an initial prestress or initial displacement or initial jack force to strands. Then hold the prepress and cast the concrete beam. After one day, release the prestress and observe the behavior of the released prestress on the concrete cross-section. Can anyone help me to model this system with detailed answers/steps/screenshots?
I have attached the file, please check and correct the error, if possible.
 https://files.engineering.com/getfile.aspx?folder=58f8715b-616f-4028-a2d0-a4f3cbb311d6&file=PSBeam_Disp.cae
As per the error message, you have to use general contact if you want to include surface-based cohesive behavior in this analysis.
Thank you FEA way for your message. Can you please proof check my file and share it here again?
