Precast Compound/ boundary wall design 1
ak.t
73
Hi All,
Can u provide me a sample calculations for earth pressure and stability check for the same.
It is a precast boundary /compound wall. Kindly refer attached sketch. Thank you.
Not much earth pressure in in 750 mm; like any wall, Ep = 1/2*gamma*Ka*H^2; the wind is the wind, P*A. However, for overturning and sliding you have to apply the resultant wind and earth pressure forces rom the panel to the fence posts. Then calculate sliding, overturning, bearing pressure, as you would for any retaining wall.
Thank you so much. i will follow this and i will post the same
