Ben29
- Aug 7, 2014
- 324
I have an existing facility where the client wants to install a CMU block fire wall partition on the double tee slab. The building is circa 1973. The block wall will run parallel to the tees and will be centered between the tees. Is this something I can conservatively calculate based on minimum information that I have?
The second image below shows the cross section of the slab where it was cut for installation of a staircase. It is hard to tell if this is a 4 inch flange + 2 inch topping. What do you all think?
