Daparojo252
- Mar 25, 2015
- 11
Dear All,
I am after guidance, and would like someone to check to see of I am on the right lines.
I have need a fastener that needs a preload value 70% of its yield.
Material has a yield of 600 MPa, therefore 70% is 420 MPa.
The Cross-Sectional Area of the fastener is 1000mm2 (smallest undercut).
Therefore the Pre Load required is 420 x 1000 = 420 kN
Pre Load = Clamp Load
The Clamping length is 90mm, the nominal thread of 40mm diameter.
If I was to use tensioning rather that torque tightening for a more accurate way of stretching and minimising losses, then the load losses approx. :-
40/90 + 1.01 = 1.45 x Pre Load = 609 kN Of Applied Load to the Bolt to retain 420 kN Clamping (Preload) over a short length of 90mm.
Now, that would mean that the stress in the undercut 609 kN / 1000 mm2 = 609 N/mm2
Stress in Bolt is greater than the yield of the material, therefore it would fail.
I would have to specify a greater material yield than originally specified.
Am I on the correct lines, or am I missing something.
