Pressure differential 3
DRSEngineer
I am a fairly new engineer, recently graduated. I have been given a pressure vessel problem and I need some help. We have a dome shaped lens with a small lip which gives us a certain surface area to which we apply the adhesive. Currently the adhesive has been failing at 40,000 ft. I need to find the PSI inside the lens at 40,000 ft above sea level, so I can determine a proper adhesive to use. Can anyone direct me to the proper equations that will help me determine the PSI acting on the domed lens?
15psi is an awfull big pressure ... is the lens on a box sealed at SL ?
I will verfiy the internal pressure with my supervisor but is the rest of my reasoning correct?
Yes, the equations will work for that. To be safe, I'd assume that Di = De unless you're pretty sure the internal pressure isn't acting on the contact area of the epoxy.
