Hey guys,
I'm modeling an adapter that will go inside of a pressure vessel holding 2500psi. The adapter is basically a cylindrical piece and it will be threaded into the wall of the pressure vessel. It will be submerged in water, thus bringing the need for various o-ring seals.
My question is - is there a good way for modelling the pressure distribution on the cylindrical faces before and after the oring seal? The area looks like this:
face O face
ring
maybe the left face would see 2500psig, and if the oring is holding up correctly, the back face will see 0psig? Is this a reasonable assumption when conducting an fea? I am simply concerned about the life of this adapter, but I am having trouble figuring out the most realistic distribution of this pressure. Thanks
face O face
ring
