Ok I am really stuck here and I need your help!
here is the information I have so far :
I am pulling facuum on a vessle using a jet, and I know the pressure at the jet and the pressure at the vessle. I have a valve mid-way and I need to know the pressure going into this valve and the pressure leaving the valve. I have measured and accounted for fittings from the vessel to the valve and after the valve up to the jet. I have calculated the pressure drops associated with the piping and fittings but I still do not know how to find the pressure drop across this valve.
inlet pressure : 49687 Pa
Type : Ball Valve
Cv : 104
Type of FLow : Air ( this is a gas not water)
What is the correct formula to find the outlet pressure, this formula must take into account the Cv.
Also, what I want to do is see if this pressure drop will be different if I replace the valve with a 2 inch GLOBE valve with a Cv or about 50.
Please help me out on this one guyz...I would really appreciate it.
shup
Type : Ball Valve
Cv : 104
shup
