Pressure drop due to contractions or expansions.
dbecker
138
I have two questions,
1. When calculating the pressure drop due to an abrupt contraction, do I use the minor diameter or the major diameter with equation 3-14 of Cranes (page 3-4)? It calls for a diameter, and I don't know which to use.
Same question pertains to an expansion.
2. I noticed there are a few equations out there on calculating losses due to contractions.
One equation is, K=0.5(1-beta^2) for 180 degree abrupt contractions as seen in Crane's page A-26 Formula 2.
The other is K=0.5(1-beta^2)^(3/4). I got this from the web.
Why is one raised to the 3/4 power and the other is not, this deviation is confusing and I don't see a case basis where one is used and the other is not.
Please explain.
Thank you!
1. It does mention in the Text of Crane that if you use K1 values in Eqn 3-14 then velocity is based on smaller pipe if you use K2 values then velocity is based on larger pipe. See the note following Eqn 3-18.1 on page 3-4 (assuming you have the same version I have).
2. My reference texts (although a bit dated) only show the equation in Crane or slight variations of it (e.g., different coefficients such as 0.42 rather than 0.5). None have an equation with a different power although I did a quick search and found the same as you ?
Thank you rneill.
I read that note but it only refers to equations 3-17, 3-17.1 and 3-18, i did not know it also referred to equations 3-14. But thank you for clarifying that anyhow.
If I am correct, as beta approaches zero (D1~0) K will approach 0.5.
