Feldmann359
Industrial
- Jun 9, 2009
- 28
Dear colleagues!
I have again an other hydraulic challenge:
Whe perform pressure drop measurements with water at ambient
temperature.
Now I have to predict how the pressure drop would change if, for example, the temperature rises or a different liquid will be used with other fluidic properties like density, viscosity, surface tension and vapour pressure.
It should be ensured that there is always liquid - no two-phase flow / cavitation.
Are there formulas/relationships that I could use?
Thanks in advance
Stephan
temperature.
Thanks in advance
Stephan
