Regarding pressure drop for flow through a tee the pressure drop factors given in Crane, Flow of Fluids is K=20fT for flow through run and K=60fT for branch.
I require clarifications on the following:
1)Is there any limitation on tee size for using the above. Say if I have a 10 inch. pipe with a branch of 1" dia. would I be right in using the K factors as above.
2) If there is a flow division between run and branch, how do I compute the pressure drop? What are the velocities to be used for run and branch?
Thanks in advance for your feedback.
