Pressure on WOG rating 5
prosperavalve
Industrial
Feb 26, 2005
4
Hello, All,
Anyone know if a 1" ball valve with pressure in 3000# WOG rating means the same as 1" ball valve in ANSI Class3000LB?
What is the different between WOG rating and ANSI Class rating?
Thanks.
Prosperavalve,
Don't forget to use the forum search feature. See if any of these give you what you are looking for.
thread408-114317
thread292-77959
thread408-66243
thread378-41856
thread408-27676
I don't believe there IS an ANSI 3000. ANSI (Now ASME classes are 150, 300, 600, 900, 1500, 2500, 4500. Ref B16.34.
However 3000WOG is a do-not-exceed pressure, at normal ambient.
Thanks for all your response.
So there is no equivalent between WOG rating and ANSI Class rating. So if the maximum working pressure is 3000# WOG, what pressure for the ball valve should I choose?
Thanks.
When you say "the maximum working pressure is 3000# WOG" do you mean that the design pressure of the piping system is 3000 psi ?
If that's what you mean, then you need to choose a valve with pressure rating of at least 3000 psi at your design pressure.
Valve pressure ratings varies with temperature and material of construction even for the same Class. For example, a ANSI Class 1500 carbon steel valve (material group 1.1 per ASME B16.34) has a pressure rating of 3705 psi at 100 F(pressure rating of this same valve drops to 2995 psi at 500 F), while a 316L Stainless steel (material group 2.3) valve of the same Class 1500 will have a pressure rating of only 3000 psi at 100 F (1910 psi at 500 F).
You should check ASME B16.34 for pressure rating of the valve material you want to use.
