CuriousElectron
- Jun 24, 2017
- 186
Greetings,
Are the typical pressure switches suited for all fluid pressure measurement applications? What I mean by this, is can I use the same pressure switch(as long as the process range is correctly specified for the process being measured) in application containing pressurized oil, air and pressurized water?
The device would be measuring the pressure, regardless of the process fluid.
EE
EE
