TheRaven
Industrial
- Mar 20, 2014
- 3
Hi Folks,
This is my first post so please be gentle. This is also a bit of a yarn so please bear with me.
I am the H&S manager at the company I work for. We want to start pressure testing pipework on site and I have done some research into this. The HSE guidance note (GS4) states that as a minimum the material should be 3mm thick mild steel to prevent projectiles piercing the test enclosure. So this is the advice I have put forward.
I have just has my MD come and see me to say that he has found a company that makes prefabricated enclosures and that the panelling is made up of a layer of 1.5mm thick steel, some fibre glass then another piece of 1.5mm thick.
So my question is this; Does two pieces of 1.5mm thick steel have the same impact strength as one solid piece which is 3mm thick?
Any help would be very much appreciated.
Cheers,
TheRaven.
Cheers,
TheRaven.
