pressure testing stainless steel fittings
mflower
Industrial
Jul 14, 2006
Is there an ASTM standard for Pressure testing NPT fittings for 15,000 PSI working pressure use?
What is the Standard that you are using to purchase these threaded fittings, ASME B16.11 or what?
The service is High Pressure water blasting.
There are no ASTM specs based on service pressure. That is your responsability as the user. You need to look in the piping and fitting codes for guidance on pressure ratings.
Rust never sleeps
Neither should your protection
