dursunlutfu
- Jun 9, 2018
- 47
I have a wood column inside of a wall carrying a beam supporting a shear wall. Due to the overturning, I have almost around 10kips coming to the sill plate. I was wondering how I should analyze the distribution of the point load over the continuous sill plate which is also taking minimal point loads from the wall studs. Also, can I assume the footing as a rectangular footing and distribute the load for example for 16" width x 48" length. Do you guys think that approach is logical ?
Thank you for your time,
