KevinNZ
- Jun 12, 2003
- 844
A customer is installing a custom pipe spool within a piping system, simple flanged 'spool' as below. Different material (thicker and higher allowable stress) to the piping. The problem is they require the spool to be designed as a pressure vessel (ASME VIII-1) rather than a pipe spool. Now as the piping designer how do we show the 'nozzle'/body loads from the piping are OK to the vessel code? Any shortcuts? Can we just say the piping stress will be higher than the spool and piping calculations are no less conservative than ASME vessel calculations?
The spool/vessel designer is not being supplied any piping loads, so we will not be getting the calculations from them.
Trying our best to convince the customer to change to the piping code and we just include the spool in the piping stress model.
