staticmh
- Aug 28, 2019
- 57
Hi Folk,
Good morning!
I want to know that how static head adjustment can be performed in calculation while we are performing the hydro test in vertical position and vessel to be erect in vertical position.
i'm designing a vessel which is being verified on UG-99(b) & UG-99(C) for both shop and site.
I got an comment from client on my calculation that " Since the Vessel orientation is vertical, Static head shall be adjusted in the test pressure during hydro testing at horizontal position"
My vessel data is below stated:
O.D = 610mm
Thickness shell = 12mm
Shell Length = 2550mm
Orientation = Vertical
Shop Test = Shall be Horizontally
Site Test = Shall be horizontally
Could any body please guide me that how to encounter the client comment. As i have been read the code ASME SEC III Div. 1 and states that, for vertical position static head shall be include in the test pressure value.
whereas, for horizontal vessel there shall not be any severe static head to be calculate and nor included.
Furthermore, please advice with your experience.
Good morning!
O.D = 610mm
