ayelamayem77
- Oct 2, 2012
- 47
Dear all
[highlight #FCE94F]my question seems to be silly !!!![/highlight] but please be patient and think with me about this rule in asce7-05 regarding dual frame system
[highlight #FCE94F](resistance to lateral forces is provided by moment-resisting frame capable of resist 25 present of the design base shear)[/highlight]
all i mean that i want to activate this rule in Etabs program, so i made a separate model and i applied 25% of total base shear, i need to design the columns under this seismic load case situation as you know the design in this particular case should be made under load combination consists of (seismic and gravity loads) as follows
(1.2d+1.0E+f1L+f2s 2006 ibc eq.16-5) & (0.9d+1.0E+1.6H 2006 ibc eq.16-7).
[highlight #FCE94F]I want to keep the shear walls in this model am taking about to support gravity loads with the columns according to their stiffness, because if i remove the shear walls the columns will be subjected to high axial loads in accordance with the seismic forces, which will lead to big columns sections when i start the design by Etabs.
In other words in most design cases in dual frame system or shear wall-frame interactive system the resent rule in asce-7-05 will governs the design of columns.[/highlight]
thanks all for your support
