thedesigner75
Automotive
- Jan 6, 2023
- 16
Hello All,
i can not get this concept: if i have a not so rigid part like an injected molded part...this part has a feature, sort of planar small surface, that is the datum feature that represents the primary datum so how can i qualify this primary datum in term of orientation? i can put a profile tolerance to check that the surface is not so rough, for flatness checking, and this is clear to me, but if this surface is bent? I need to put some orientation tolerance but to what datum as that is the primary datum
? Thank you for your time
Ciao
![[ponder] [ponder] [ponder]](/data/assets/smilies/ponder.gif)
Ciao
