Primitive modeling 1
MotleyTool
Aerospace
I know we all have certain techniques and preferred methods. But I have to ask anyone out there. We recently had a discussion of parametrics at work, one gentleman claims that primitives are NOT parametric and should not be used. I disagree, as I understand that UGS does not think this is a preferred methodlogy, it is still a valid modeling approach. Good gosh! I would think we all do not have to model ONE way to achieve optimal results. If not I say lets get rid of 80% of the features and mandate one technique. What do you guys/gals think.
Tony
The primitive features themselves ARE parametric in the sense that their size can be modified by editing their defining expressions. However, since they we intended as 'base features' only there is no way to parametrically modify their locations in space parametrically. So if one were to take a 'Block' as the base object and then create a 'Cylinder' and subtract it to form a 'hole', while the size of the Block and 'Hole' can be changed, the location of the 'Hole' cannot be. So in some aspects, you're both right. And because of that, we only feel that primitives are sutiable as 'base features' and not to be booleaned to define detailed features, such as holes, pockets, bosses, etc. (use Form Features). Also we don't think that combining several primitives together to define some complex cross-sectional shape is not a good practice either (use Sketch and Extrude).
Anyway, I hope this helps.
John R. Baker, P.E.
Product 'Evangelist'
UGS NX Product Line
SIEMENS PLM Software
Cypress, CA
If you consider Knowledge Fusion in the mix, primitives are no longer dumb in location and orientation. I personally design as close to manufacturing processes as possible. What that means is a hole looks like a drill bit, a machined edge has a look like a milling path, etc. I even go as far as building the tooling die appearance and using it as tool off of a block if that is the process.
KISS theory.
-Dave
When I wrote our company's CAD Standards I tried to include some best practices. One of them was to do with the first feature that is created in a model. Basically, in my view you should start your model with either a primitive, a sketch or a linked body. From then on you shouldn't need to use any of the primitives.
Tony,
I'm with you for the most part, not to say that I'm against what John or anybody else has said here. All good advice!
Primitives are parametric in their overall dimensions, and the can be moved using the move feature function. It has to be said that when positioning holes and pockets relative to faces then maintaining those relationships using by moving separate primitives about is vastly inferior.
What I will say is the UG has lots of really powerful tools that each have their uses, and I do believe in using them. I advise people to do things a certain way for a whole bunch of reasons, but I have to make room for people to be as productive as they can in their own way. At the end of the day getting the best "Bang for your buck" out of the CAD system relates in part to how the CAD system enables people to work productively. I think UG is one of the better CAD systems for doing that because it is flexible.
Examples of what we do ask users to do are things like separating booleans from feature creation, (i.e. extrude can be united or subtracted at the time of creation, but we don't prefer that). This is simply to make the structure of the model a little more visible on the feature list and easier to maintain.
I'll go one step further that talking just about thinking like a manufacturing process. We often work up studies ad preliminary models where we design very conceptually, which is to say we don't know how the model is going to come out until we're done hacking away at it. Sometimes it has to be built like a tool, other times you're packaging for space by chipping away at the target solid to come up with a usable result. Under these circumstances we often don't know whether the concept will develop into anything worthwhile so we cannot afford to invest a lot of time into it. Often I'll use your technique of slicing away at primitives which I unite subtract intersect etc... I use far too many replace faces and offsets for comfort, but the job gets done possibilities are proved or disproved and we progress from there.
The temptation is to progress the best study into the production model. Our system is to distinguish between study models, that you probably wouldn't wish to maintain, from production designs where some thought is put into making the model maintainable for the next guy. Truth be told working from the basis of these fairly anarchic study files means that we have learned to avoid what may be described as overly complex associativity. This is as opposed to not wanting to work parametrically. What we want others to think about is how they can put together models that are easy to work on, (i.e. they can be changed easily).
The opposite to this is where somebody builds every feature in a model associated about a base feature which can for ever after never be changed without destroying the model. One such example was a small pocket with a hole in the middle. This was a notional interface point of in a large and complex panel. When the method of interface failed to work the pocket had to be removed which orphaned the simple hole and almost every other feature in the model. We were easily able to add a feature that removed the pocket just before the final hollow, thereby saving a lot of trouble, but I would have been better satisfied had I been able to remove the pocket discreetly earlier in the model without too many problems. The CAD system wasn't to blame, the person who made the model made poor choices in hindsight for what may have initially seemed good reasons. He failed to keep it simple stupid, (and never heard of Murphy's Law).
Hope this helps find the path of CAD enlightenment!
Hudson
