Hello all,
I'm very experienced with designing and making drawings for fabricated metal parts (cut, machine, form, join, etc), but now I've stumbled into a situation where I need to design a cast component. I used many resources to make sure that the design itself is manufacturable: draft angles, parting line geometry, uniform thickness, features to encourage smooth mold fill. So I'm not too worried about that aspect.
The drawing on the other hand gives me pause. The geometry definition isn't a problem, I have a lot of GD&T experience from supplying big OEM's in the past. It's all the fiddly ancillary notes that I'm worried about. From my prior work, I know that the devil is in the details when you send drawings to a supplier.
In a perfect world, I'd collaborate directly with a supplier to understand their requirements and capabilities, but these are prelim drawings to go out for quotes. Even so, I don't want to spend a month going back and forth trying to get quotes because I forgot to specify surface finish or something along those lines.
Can anyone give some tips as to what "special" info a caster needs vs a fabricated or machined part? A pile of example drawings would be spectacular, I learn fastest by synthesizing examples.
Edit: I just found ASME Y14.8 and requested they purchase it, but advice from experienced people is always best!
