Print Driver for Ricoh MPCW 2200 SP copier/printer/scanner
KKKing
28
Does anyone have this large format printer/plotter that is able to plot from NX9. I had it running before NX9 using a printer driver of HP Designjet 1055cm but for what ever reason, it now give the following error at the printer. Paper size and type are mismatched, it then gives a paper size under it (11x17 plain paper), when ever a print is sent. You can not over ride this condition and have to cancel the sent jobs to the printer.
From NX, I am able to use the print feature and that works out of NX, but when needing to get a true 1:1 print, we have always found that the plot function is best, when it works.
Does anyone know what to use as a print driver for this machine? [hairpull]
So I take it that I am the only company that has the privilege to have to figure out how to make work form within NX9.
Any help would be appreciated, even any off the wall solutions
