sartan
Automotive
- Feb 24, 2002
- 2
Are there any detailed instructions on how to correctly set up jdk with pro/e 2001. In 2000i2 I managed to write some code that added menu items to the Applications menu on the pro/e interface and all was well. Since upgrading to 2001 pro/e loads then locks up, the only way to fix it seems to be to open the config.pro file and delete the protk.dat location line. I've tried countless combinations of CLASSPATH and path variations but to no avail.
I'm using jdk1.1.5 as this worked fine on 2000i2, does any one know if it works on 2001? Any suggestions at all would be appreciated.
