pro/e drawing file to autocad drawing? 1
cranekiran
99
Dear all,
I tried sending a pro/e drawing in dxf format which I wanted it to open in Autocad file.The drawing came in fine in autocad 2000,but after I tried to alter some dimensions in autocad ,it gave a error message and the drawing simply went off the screen.I logged into autocad again and then the same thing happened.
I have given up on this task now.All I want to know is Can it be done?
Thanks in advance.
Cranekiran,
Why not export PRO/E drawing files in dwg format(Autocad native)?
-Hora.
I have exported to DWG and found that the file can be open and edited, but the dimensions do not come in scaled properly. This is a particular problem with multi-sheet drawings at different scales. Make a note of the drawing scale on each sheet. This works well.
Best Regards,
Aron
In Pro/E, you have to change the unit to that you will use in Autocad. I have tried, it is ok.
Cranekiran,
I have had similar problems, the best way I have found to work aroud it is to use edit>copy (use a window to pick all your entities) then paste them into a new drawing.
Good Luck
Hayden
Thanks Hora,
I did try exporting pro/e drawing in DWG File and It was a success.
1)Save the pro/e drawing in Dwg file
2)open in Autocad.
It is surprising it was that easy.
