Pro/Engineer Data Migration to PDM
jayanthi
Is there any way to list out my parameters from the model/drawing without opening the part in Pro/Engineer or without opening Pro/E? .
The beginning portion of a Pro/E file is text data that has all of the parameters in it. How much digging do you want to do?
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Loosli,
The scenario is...I have created few parameters through Setup-->Parameters-->Create and assigned 'values' to them. These values would help me to identify the part and its BOM structure.
I need to know, how can I list these values along with the parameters, without opening the part/assembly/drawing in Pro/E.
Thank you,
Jayanthi
Did you designate the parameter that you created? If it is designated then the parameter name and value will show up in the beginning of the Pro/E file. You can open the file with a text editor to look for this value or write a program to search for this parameter within multiple files.
