Pro/Mechanica and WinXP?
  • Thread starter Thread starter -
  • Start date Start date
Guest
I have previously run Pro/M in Windows2000 and it worked fine. I have now changed to Windows XP and it dosen't seams too work. I just can't install it.
It's very frustrating and i'm woundering if anyone now how it install Pro/M in XP IF it's possible...
Runs just fine on XP. Are you using build 2001430? They just posted a patch on their website too, probably unrelated to your problem.
To point out the obvious,
When you got a new puter, did you get a new license pack?
If you will run Pro Engineer under XP, you MUST make sure that your harddisk is NTFS-formattet, otherwise the program will not run.
Hope this can help
Michael
