Problem loading VBA project in CATIA
Daniel Popa
Automotive
Sep 23, 2016
19
Good evening everyone
I had to reset my user on my computer due to some issues (not related to the following question). After doing so I have found myself having to bring back all the setting I had in my Catia environment. For some reason, every time I try to load a specific VBA Project into the library i get the following error message. I have changed the library permissions and unless I have missed something there I do not see why this is happening.
Any help will be much appreciated.
Thank you.
PS. I had to hide the path for confidentiality reasons. But the file is there.
 http://files.engineering.com/getfile.aspx?folder=ffb6d125-a3d2-4395-aea2-42678c8606b3&file=error.JPG
Thank you ferdo. I did try to google the issue but I did not find a solution.
I did try that as well drewmumaw. I am 100% sure it is installed as I can use it without any problems.
