There is no one right answer, it all just depends on many circumstances. What happens when lightning hits the line/shield? How often does it happen? What happens to system stability if the lines in question trip and reclose? Just because you have a shield doesn't mean that the line won't trip when the shield is struck as the potential across the insulator may become higher than the insulation rating. What we might do in the land of unshielded 500kV is probably different than what might be done in locations where distribution circuits are built with the neutral on top as a shield wire.
You have to study your particular installation and make your own determinations. Those answers would be appropriate for that location, but might not even apply elsewhere on your system.
For me and my system, lightning is so rare that it doesn't make sense to worry about it. In Florida lightning caused misoperations are so common that they'll reclose once on bus diff trips. Again, no one right answer.
