problem Tools -> Record NX10 flyouts are not recorded
obe0009
50
I have seen the NX10 function Tools-> Record work OK with a standard install.
But I work on two different PC's both installed with a version of Camtasia.
When I try to record some constraining (eg Collinear) the flyout menu is not recorded.
When you wait long enough the help text is displayed and this is recorded properly.
See attachment.
My question can anyone verify this problem with NX10 and Camtasia version installed.
Olaf
 http://files.engineering.com/getfile.aspx?folder=8c637a35-2af6-406b-93dd-464b81003424&file=movie.avi
I can't replicate that issue with NX10 and Camtasia (see pic below for Camtasia version and video).
download.aspx
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
Yes, I've found that when using Camtasia directly, all the on-screen items will be captured. However, if you use the built-in NX Movie capture, these on-screen items are often missed. I'm not sure why that's that case but I've seen it before and that's why we always use Camtasia when we want to make sure that the video is of the highest quality and with the most content, like the on-screen items.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
If I guess, i would that it depends on the graphics adapter/driver rather than the Camtasia.
Try lower the hardware acceleration and then try capture again.
Are you running a certified graphics adapter / Driver ?
Tomas
